MxzKing
- Oct 17, 2013
I have a 08 RTX with 2300 miles. It has good fresh gas in it. When I take off from a stop if I stab the throttle to take off it will stumble and sometimes stall. But if I give it slow even throttle it's fine. Any suggestions on what to look for?
Ice_fisher
- May 7, 2014
- Manitoba
- Yamaha Venture MP
How is the sled at steady throttle higher RPMs any missfire or stumble? You could try a bit of Seafoam in the fuel and see if it clears up.
MxzKing
- Oct 17, 2013
It's great at steady throttle and yesterday I had it opened up on a couple trails and no issues. It was coming to cross roads I would tap the throttle quick a couple times crossing and it stalled a few times.How is the sled at steady throttle higher RPMs any missfire or stumble? You could try a bit of Seafoam in the fuel and see if it clears up.
Surestick
- Jan 19, 2015
- '07 Phazer Mountain Lite
When I got my '07 Mountain Lite a couple of years ago it was doing that occasionally. The idle was set below the minimum and it hasn't happened again since I adjusted the idle correctly.
It's supposed to idle between 1700 and 1900 rpm. The adjustment screw is behind a rubber cap on a panel slightly inboard and behind the left front shock.
MxzKing
- Oct 17, 2013
I'll be sure to check that. I bought new plugs and Seafoam it's currently at the dealer for the wire harness recall it started having an intermittent no start Monday.When I got my '07 Mountain Lite a couple of years ago it was doing that occasionally. The idle was set below the minimum and it hasn't happened again since I adjusted the idle correctly.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Also blown exhaust dognuts along with low idle will cause that.
