bluegrass
- Mar 6, 2007
i put a set of pilot skis on my 2012 xtx with 6 inch carbide in the center and 4 inch on the out side and this thing jumps and darts all over the place i am running woody carbide i see alot of pepolpe running this ski what am i doing
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Check you toe out on your skis. Make sure you put a bungy cord across the front of the skis and set them 1/4 to 5/8" (toe out) mine I set at 5/8" others set from 0"-5/8". I don't have darting issues, but I run the Yamaha tuners wit 4 and 4.
Good Luck
Pete
Good Luck
Pete
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
On my brothers Nytro with Pilot skis we had to add a 5/16" shim to the rear of the ski rubber and set the toe to what herndonp said. They are good ski's for that sled!
sofunkingcool
I have my toe out set at 3/4 with pilot skis. Shaper's bars 7.5 in the middle 6 on the outside, on a 09 shorty. Sled handles awesome. Studding and having the rear and front suspension setup properly play a big role on how the sled will handle as well. Lots of posts on here about different setups that worked.
sofunkingcool
I have my toe out set at 3/4 with pilot skis. Shaper's bars 7.5 in the middle 6 on the outside, on a 09 shorty. Sled handles awesome. Studding and having the rear and front suspension play a big role on how the sled will handle as well. Lots of posts on here about different setups that worked.
