big guy
I installed a set of snowtracker extremes on my pilot 5.7's. I am running 4.5" shapers on the outside of the ski. Should I remove the shapers or leave them in?
Thanks.
Thanks.
trailmarker
i have 6" shapers on the outside, not a problem.
try it, if it is to much effort take them off(outside) and try only the snow trackers
big guy
Will do. I can't wait!!!!!
big guy
Finally had a chance to put some miles on my Snow Tracker Extremes. They work very well!!! I have absolutely zero darting. But still have slight pushing in corners with soft snow. On hard pack they rail!!! Wish I would of bought these 3 years ago! Very happy with them.
pedros1983
Yeeep same here!! Snowtrackers completely transform the apex's handling. Awesome product!!
Trailbuster
What are snowtrackers? are they the dual carbides?
big guy
Here's a link for you.Trailbuster said:What are snowtrackers? are they the dual carbides?
http://www.motovan.com/catalogupdate/ja ... 28JA08.pdf
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
big guy said:Finally had a chance to put some miles on my Snow Tracker Extremes. They work very well!!! I have absolutely zero darting. But still have slight pushing in corners with soft snow. On hard pack they rail!!! Wish I would of bought these 3 years ago! Very happy with them.![]()
big guy, do you happen to have a stiffer swaybar? My snowtrackers pushed with a 13mm bar installed. Took it out and put back stock swaybar and snowtrackers railed thru the corners again.
big guy
Actually I do have the 13mm bar. Thanks for the tip I will give it a try.
KnappAttack
- Feb 19, 2004
- Welch MN
big guy said:Actually I do have the 13mm bar. Thanks for the tip I will give it a try.
I figured as much, you'll like it much better with the stock swaybar back in place.
IMO that stiff bar should only be used as a fence post, but the Snowtrackers are the best find ever for the Apex!
Trailbuster
Thanks Big guy. They sure look like they'd do the job right. so do they bolt on to the factory skis?big guy said:Here's a link for you.Trailbuster said:What are snowtrackers? are they the dual carbides?
big guy
Yes. Just buy the ones for the yammi ski. Here's a link from Yamaha site.
http://www.yamaha-motor.ca/accessories/ ... 92&group=S
I bought mine from Royal Distributing a little cheaper.
