placement of 5 wires off battery help please
srx700pilot
I replaced starter motor and don't remember locations of the 5 wires. I assume 2 go to battery positive and 2 battery negative, where does the big 5th wire in back of picture get grounded to? Does it go to the starter motor bolt? thanks.
You are correct on the 2+2 that go to the battery, the large black wire shown looks like it should go to the starter bolt but it appears you already have a wire installed there? Hard to tell for sure in the pic.
Other than that it could be the negative jumper/charger lead that sits with the positive red lead adjacent to the oil tank, but it should have a rubber sleeve over it to keep it from touching anything.
