Please Help. Can't find the thread installing the DC Plug
It's about as simple as it gets. Just remove the hood, and side pannel. On the left side of the sled (as you sit on it) find the wire harness behind the rad, you'll see two wires with a white connector on the end. The connector has a cap on it, no wires coming out of the cap. Remove the cap plug in the 12V outlet, place it in the hole, and put the lock ring in.
if you have an 08 fx nytro (except mtx) it isnt as simple as that. there is no existing wiring for a dc plug. and you will need to wire your own. ski
see my signature.
