347strokin
What are you guys paying for your S/C pulleys? I got a rough quote over the phone from a dealership in Alberta here saying they are roughly $150 each.
I'm running a 27 T crank and a 23 T blower which puts me around 16 lbs.
I was told I'll require 2 - 25 T tooth pulleys to get me around 10 lbs.
This is an Apex Stage 2.
Does this sound right and where are you guys getting your pulleys from?
Thanks.
Thanks.
tko47
I get them from MPI about 90 bucks I run a 28 and 22 on top works well..
TurboJamie
Gates makes the Pulleys in Steel you can get them from a local bearing and belting supplier I was paying around $30 a pulley.
347strokin
tko47 said:I get them from MPI about 90 bucks I run a 28 and 22 on top works well..
tko47, where does this put you for boost?
Are you still within the 150,000 blower rpms?
347strokin
TurboJamie said:Gates makes the Pulleys in Steel you can get them from a local bearing and belting supplier I was paying around $30 a pulley.
I'll have to check out what Gates has. Thanks.
tko47
I think with the 28-22 i'm at 131,000 at 10,500
tko47
18 psi at 10 above 1000'
Skydog
WOW that sled must FLY!!!!!!!!!!!HAHAH
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
The stage 3 mpi have a supposed limit of... 100000rpm.
I will try 27 bottom/24 upper to see... should be near 30 psi then...
Skydog
30..............hahahah
tko47
it goes ok I want to ride yours at 30!!!!
can we source these belts from Gates as well?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Skydog said:30..............hahahah
that is for real.
I actually get 20# of boost from my current 27/27 pulleys.
I juste got a set of 26, 25 and 24 teeth pulley... so I will do some experiments
My bottom pulley can't be changed easily because my hall effect sensor magnets are into that pulley (standalone efi on rx1)
Skydog
No no i sure it does i just was saying NUTS!!!! WAY WAY FAST!! HAHA
Skydog
Skydog
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Skydog said:No no i sure it does i just was saying NUTS!!!! WAY WAY FAST!! HAHA
Skydog
I will let you know once I try this.
Its already nuts on trails at 20#
