This is very common. It is due to lack of belt squeeze at engagement. An ultimax xs805 is a more expensive belt than oe belt, but is softer and has more grip. The belt change helps but to further remedy the problem swap your primary spring out to one with a lower preload but has a similar spring rate and finish rate. I recommend the o-p-o, short or long, the short being the lowest engagement of the two. A more aggressive weight will also add belt squeeze force but may not be what you are looking for.
