primary spring /rpm change
justinator
Maine
2023 Arctic Cat Riot 9000
Is there a rule of thumb for rpms and spring force?? What I mean is lets say a guy needs 300 rpm more out of a set of weights and he wants to change springs to do so, how much more force does he need......20lbs is equal to how many rpm??
I can't see how a spring with 20lbs. of more full shift will yield 300rpm at full shift. Turk or Srxpec should may chime in to give you a more accurate estimate.
