petetown
- Jan 6, 2012
- Melville,SK
- 2011 nytro xtx boooooosted!!!
I was wondering if anybody would be able to share what there fuel controllers settings are for this unit 0-3000 ft if that matters also I am running the 45 helix with the secondary wound to 70 looking for a starting point for the 50y weights maybe someone could recommend better clutching setup? 10lbs boost flatland/backcountry setup nytro xtx with 2.25 paddle stock gears buy 8 tooth 2.52 extros so that should have it geared fairly low..thanks in advance
