scotstr
- Mar 23, 2006
- South of Buffalo, NY
- `07 RS Rage, `04 RX1 LE-Dead
Has anyone installed an oil cooler on their air cooled wheeler? I've got a '99 Timberwolf 250 4x4 I'd like to put one on. I have a small automotive transmission cooler I think would work ok. I'm not sure exactly where to drill and tap and attach the 2 lines. Thanks.
i know the big bear professional has one on it as did the older big bears. it came off of the tranny by the transfer case if i remeber correctly. if the wolf has the same bottom end as the bears do it might have a bypass plate or pipe on there already that you can remove and plumb it in there. i know on my bear the hoses for the cooler run beside the drive shaft for the front diff on mine.
