MIDWAY
- Feb 12, 2008
- SE, MN
- 2015 Yamaha Viper LTX SE with Push Turbo
I ran into a fence at the end of the season last year and have been replacing my hood ect... Ever since the accident my speedo doesn't work. I looked at the wires going into it and there was a couple of the wires that were exposed do I taped them up but the speedo still does not work. It worked fine before the minor crash. Everything else on the speedo pod works RPMs ect... Any ideas???
DV8
Do you have pics of exposed wires? they may have pulled far enough out of the connector, where your not getting a connection. Have you checked your speedo sensor at the driveshaft?
MIDWAY
- Feb 12, 2008
- SE, MN
The wires do not seem to be pulled from the connector. They were not damaged very much at all. I'm not sure how to check the sensor but the crash didn't affect anything but the top of the hood.
Highmiler
speedo
Check your speedsensor and make sure plugged in and working.
