Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
If you took off your drive belt (between the primary and secondary) on a boosted sled and rev up the engine will it build boost?
Studroes144
- Oct 30, 2013
I'm sure it'll build boost but for it to be accurate you need to have everything up to temp and you have to have a load on the engine, any fluctuation in the engine rpm or the load on the engine will change boost levels.
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
cant see it building much if any boost without load on the motor...
Studroes144
- Oct 30, 2013
If it built any it would be very little
stingray719
Been there tried that, don't waste your time trying to check boost without a load.
Joshua
- Apr 14, 2010
- Newfoundland
Thanks for the info guys
Agree, you won't build much boost if any. I don't see my boost gauge running much more then a couple pounds cruising under load
2014 viper, mpi
2009 Phazer 144"
2014 viper, mpi
2009 Phazer 144"
