Question on replacing Turbo to Header gasket on CPR
tonykof
Williams MN
Could use some advice...
Blew out the Turbo to Header gasket this weekend on my CPR trail turbo (GT2554). (Was relieved it wasn't a cracked header!)
I can probably get at the front bolts if I take off the coolant hose & fitting from the right side of the turbo.
One back bolt (the one on the right) will come off pretty easy the other is blocked by the downpipe..
If I have to remove the 5 allen head bolts that hold the downpipe flange to the turbo what is the best way to do this? I put a little pressure on them last night & they seem to be pretty tight and I started getting nervious about breaking them off. Should I throw some heat on the housing where they bolt in?
Put a 3/8" air wrench to them? (remember these are allen head bolts)
Tony
ps when it goes back together do I use any high temp sealant on the turbo to header gasket? Or just put them in dry? I don't think there is a gasket on the downpipe side should I use some high temp there..?
Don't bother with the high temp sealer! It will never with stand the 1800* temps!!
I found that sometimes I had to head the turbo exhaust section with a propane torch to get it to let the bolts out. I had stripped a few when I was taking it apart alot. If I were doing it again I would do just that heat it with propane torch and it seems to let the bolts loose.
Are you sure that the gasket is shot ? The bolts are notorious for coming loose after a few trips. I think that the heat causes them to stretch and the weight of a 14# turbo bouncing around doesn't help matters any either.
I'm 95% sure it's gone. I'll still have to remove the the down tube to get at one of the bolts so I'll get a better look at it then. I'm thinking even if it was still in there it probably wouldn't seal up again.. I have couple gaskets (one spare)coming but I still need to try to round up a couple of springs for the ball connector on the downtube since they must have been over heated from the leak so they are shot. Anyone know where I could get them?
Got everything I needed and advice on how to do it from Jeff @ CPR.
Thanks Jeff!
Tony
