Re-installing Ohlins electric rear on Apex GT
RippinV
Milford, CT
Hey there, I am re-installing the ohlin rear shock and want to make sure I zip tie the wire back right. I noticed that the plastic sheething is broken a bit in two spots yet the wires look fine (black and white). Is there anything special that I need to do on the re-install?
Your help/advice is greatly appreciated.
JToys
make sure wires/conector at shock are zip-tied good and out of way of spinning track-> Tape up the exsposed wires->zip tie every 2in-> and make sure its tight against tunnel -> i use 2 screw-in type zip-ties to keep away from that spinning track.good luck..
Thanks crazy-wezz, I have the pics from Bruce at Pioneer, but they are kinda dark and I cant really make out the way the wire is zip tied up, however, I zipped the shock wire to the top of the selenoid and then connected to the lead from the sled. Then I zip tied the lead from the sled to the zip tie on the shock at the harness. It seems like its out of the way and will not hit anything when the shock is compressing.
