Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Question: What is the best procedure for removing and installing the rear skid? Example: sequence of bolt removal, relieving spring tension, removal of rear axle. Just looking for the easiest way to do this. I have an 04 Warrior.
Thanks, Bob
Thanks, Bob
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
go to the Tech Section
have a factory repair manual handy.if you never did the rear axel the spacers and shims can be confusing.
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
Take pictures and notes. Good luck!
- Sauk Prairie, WI
- www.ty4stroke.com
Like Airwolf says, check out the tech section. It will walk you through it...BBY
