Radar22
It's my first time removing my secondary clutch, just wondering how to do so.. I want to re-greese the bearing behind it..
2010 RTX Nytro
2010 RTX Nytro
dansranger
Unbolt it and it slides off.
sledder454
remove belt, remove the bolt holding it on with 15/16 socket, watch the shims and washers for the order they came off on each side of the secondary and it slides right off. When reinstalling put a little bit of grease on the splines and shaft and torque bolt to 46 foot pounds
Radar22
Thanks for the help...
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
The bolt holding the secondary on is METRIC
sledder454
Yes the bolt is metric. But i dont have a metric socket that big so a 15/16 socket also works
Radar22
Do all the stock clutches have play in and out, as well as when the brake is on forward and back, as if you were trying to rotate it back and forth? With the belt off that is..
sledder454
Yes they do they float on the jackshaft
Radar22
Right on, thanks...
