Northernboy
I need to replace one of the front/inner idler wheels where the front suspension is bolted to. I checked the Yamaha microfiche and they are $70 each...is there a better replacement? Can larger ones be used here? I would like to find an aftermarket replacement that is easy to get in Canada.
TIA
NB
TIA
NB
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
You can go with 135mm but if you do you should replace all idlers with 135mm so the rails have the same stress all the way around. Don't just replace the one broken stock idler with a 135mm.
You can get the stock size idlers from Kimpex...They work but they're a bit cheap...
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
Invest a little extra money and buy ulmers kit with replaceable bearings. Save you time money and hassle down the road.
Northernboy
Thanks guys, I would get the Excell kit but I don't want to wait 2 weeks since crossing the border takes delivery time. I was hoping to find a good replacement here in Canada. Anyone have p/n for replacements?
I talked to my dealer and he has a cheaper replacement. I'll look at larger wheels for next season. Thanks again and Excell wheels look good.
09nytro
schmidt brothers has a nice hyfax saver kits too just something else to look in to , i'm going to put them on this summer .I'm syre you will find something to finish the year out just sucks everything is in the states and takes so long to get to you
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Check Sled werx! They're Canadian and have the Excell wheels in stock
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
canoehead said:Check Sled werx! They're Canadian and have the Excell wheels in stock
Good call...Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Goto Yamaha Canada's website and in the parts and accessories section is a $25 or $30 replacement wheel there. It has a replaceable bearing.
If you're suffering from excessive slider wear, I'd recommend getting a set of Excel motorports wheels, as they are a bit larger.
canoehead
- Jan 14, 2011
- NE, Alberta
billymx815 said:canoehead said:Check Sled werx! They're Canadian and have the Excell wheels in stock
Good call...
If your really stuck Royal Distributing has stock replacement wheels (135 mm) for Poo's and Doo's for $28.00 each. They have a 6205 bearing and are 3 mm wider than a 6005 bearing but I hear they'll work too. Good Luck!!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Don't install the Royal ones between the rails. They wil not be centered between the drive lugs and rub, killing them in no time.
canoehead
- Jan 14, 2011
- NE, Alberta
You're absolutely right I forgot to mention that they're only good for outters. ThanksGrimm said:Don't install the Royal ones between the rails. They wil not be centered between the drive lugs and rub, killing them in no time.
