siberianhusky
What would be the best replacement plug for my Nytro? I have heard NGK CR10ek and CR9EIX? Thanks !
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Cr10ek,they have a double ground strap for better performance=a couple horse power
jb_008
- May 21, 2012
- Sault Ste. Marie, On
- Yamaha Nytro RTX SE 09
Just changed my plugs out for CR10EK's myself, from all the reading I did that was the way to go. Someone did a dyno test with almost 3 more horse power with those vs stock. Apparently the other one you have listed does not produce the same result.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I ran the stock plugs, the CR9EIX's, and now I have the CR10EK's, and there wasn't any noticeable difference.
DelgatyXTX
I just put CR10EKs in mine. They're pretty inexpensive, about the same per plug as I paid for my 2-stroke.
siberianhusky
Thanks guys! 10EK's it is!...........
- 14K
