Ak Yammy
Picked up new slides just pulled original silders off and new ones they sold me are about 2 inches shorter. Checked Part#'s and they match up (SMA-8FU92-00-BK (replaces 8FU-47421-00-00) just making sure the missing last 2in. are OK.
Also are these the wide ones I've heard about.
Thanks.
Thanks.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Ak Yammy said:Picked up new slides just pulled original silders off and new ones they sold me are about 2 inches shorter. Checked Part#'s and they match up (SMA-8FU92-00-BK (replaces 8FU-47421-00-00) just making sure the missing last 2in. are OK.
Thanks.
2 inches is quite a bit, especially if you have reverse.
I recently replaced mine on my 121" skidded Vector and some cutting was required with mine.
I personally would take them back and get the correct ones as I am sure the part or model/make is wrong.
Nick1945
Thanks.
The number you have listed is for the wide slides. Like Irv said, if they are 2" shorter, more than likely they gave you the wrong ones.
unclearpine
Thanks.
I think you need the 8ES-47421-00-00 ,the 8FU-47421-00-00 you have are for the Apex Gt the RTX is a longer slide
I would check with the dealer. I had a 06 Nytro and it had the same suspension in it and had the same problem with the short slidesAk Yammy
Unclearpine called it 8ES-47421-00-00 is the right one. Need to remember Mine is designated as RX10RTW. Back to the dealer I go.
Thanks to all
Thanks to all
!!Similar threads
