donkautz
- Dec 3, 2012
Had a blown fuse for the reverse actuator, pulled the actuator and found no damage it works until I put it back into the sled. Does the gear on the sled have to be moved to a different position?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Here's how I always reinstall reverse actuator... Watch Biker Mike video starting at 15:07...
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Thats the way the manual says to do it. Turn the gear clockwise until it comes off the detent block. Makes lining up the actuator screws easy. With that said it sounds like your problem is different. We've had 2 Vipers that the actuator has failed and needed to be replaced. Yours sounds more like the gear on the back of the actuator, the teeth on the plastic gear wears out. Some have turned that gear 180* with success for more life out of the actuator.
