Any problem with a 7" riser on XTX ?
yamahahaha
you would have to get cable extensions
bottlerocket
And stand on the seat to reach the ape hangers.... I have a 2.5" and they seem high.
HRD2PLZ
bottlerocket said:And stand on the seat to reach the ape hangers.... I have a 2.5" and they seem high.
X2, not sure you would like it for trail riding. I'm 5'11" and at 2.5in. my arms are slightly bent while standing.
Dimebag
Get a adjustable riser if you're not sure wich height you like..
With quick adjusters you can also adjust the height on the trail..
I got one on mine. Works great and looks awesome
stopdropanroll
LarsTh said:Any problem with a 7" riser on XTX ?
You would need to extend EVERYTHING, brake line, ebrake, throttle, and wire harnesses. I am 6'6 with 4-5.5 adjustable riser and a non-rising RSI bar and its too much if your sitting down with the bars in the high position.
09nytro
Roxs makes a very nice adjustable riser ,I also think 7 is to high but if u are 7 foot tall then a 7 would work just fine ha.ha.ha
I am 6'4, so 4-5.5" should be enough?
yamahahaha
on the nytro the bars r set high, i have a 4" and my bars are higher than an 8 inch on a rev chassis
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
yamahahaha said:on the nytro the bars r set high, i have a 4" and my bars are higher than an 8 inch on a rev chassis
X2 - 4" riser on my RTX. I'm 6' and wouldn't want it higher. Also I think any higher than 4" and you'll need cable extensions. As it was I had to re-route some of my cables for clearance.
stopdropanroll
LarsTh said:I am 6'4, so 4-5.5" should be enough?
I don't run the stock bars, my RSI bars have 0 rise in them. The stock bars account for about a 2" rise in the backcountry style bend, make sure you account for that when choosing a riser, I would say 3-4" would be plenty.
macpat
What is the tallest riser that can be put on without needing extension cables?
stopdropanroll
macpat said:What is the tallest riser that can be put on without needing extension cables?
Before I did the RSI bars I had the Rox riser 4-5.5" on and in the lowest position it was about all the further I could go, so I would say 4". But I did have a steering post relocate on it to so maybe you could squeeze 5" out of it.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
stopdropanroll said:macpat said:What is the tallest riser that can be put on without needing extension cables?
I'm pretty sure 4" is max if you want to b e certain you have enough cable clearances at all angles etc.
yamahahaha
4"
