JJWickenhauser
- Feb 26, 2006
- Stanley, North Dakota
- www.higherpowerllc.com
- 2010 Nytro MTX SE 162" MCXpress 270 kit
I had a rock go through my front cooler on my 06 Mtn. Vector. I will have to replace the front tunnel cooler. What kind of job is that? good time for Wahl Drivers?
sobfrogg
Could go 1 of 2 ways. If the heat exch is in like the Nytro you will be able to remove it with the engine in the chassis. If it is put in from the inside out then the engine has to come out.
Hope it is the first idea
JJWickenhauser
- Feb 26, 2006
I don't know. It looks like I can get it out by removing the track and drive axle. Also a ton of rivits. I am just hoping to get a used one and save a few $$$.
Thanks for any help.
totallyamaha
If the hole isn't that big why not weld it. I had the track break on my 03 rx1 and had to pull engine the coolant hoses under the engine aren't long enough to get it out otherwise
