Rox Pivot Riser
Joshua
Newfoundland
Canada
2018 Yamaha Sidewinder BTX LE 50TH
Ok I just got my 2011 Apex SE serviced. I wanted my dealer to install a 2'' riser block. He said they were unable to find one and he wasn't sure even if it can be installed on a 2011. So I went looking on the royal distributing website. And of course I found a 2'' rox pivot riser which looks very easy to install. Do anybody here have any info on a riser block not fitting on a 2011 apex and the 2'' rox pivot riser?
i have the 2" works great!... very easy to install. just make sure you have enough freeplay in cables. 99% sure you do... with riser you should have 8"
Thanks for the reply. Do I have to do anything with the cables to free them up? Like cut some tie wraps or reroute the cables?
joshsaxton97 said:
I just put one on my '06 and there was plenty of slack in the cables on that too, no cutting wire tie's or anything.
06 is shorter OEM riser
2" will fit fine with no mods.Cant believe dealer said that.Pretty sad lol.
