RS Hi Beam/Lo Beam Light switch needed
homer2210
Armada, Michigan
I need to get a new switch for my 2006 Nytro, the one I had broke off. I have looked on parts schematics and cannot locate it, does anyone know the part number or have a spare one they might want to sell. I think it might be the same for all RS models, it is small, round and gray push button that is located on the left handle switch box near your left thumb.
RS90NRL is the model name for the 2006 Nytros I believe.
Heres a link and it should be in there somewhere. You'll have to look through the sub sections till you find what you're looking for. I've bought parts from port yamaha also so they are a reputable company and believe they are a ty advertiser.
http://www.portyamaha.com/fiche_select2 ... &fveh=6868
EDIT: After a look I cant find it either. I found the housing for the opposite side but for some reason the button and left side isnt listed. You're best bet if you cant find a used one is to send the guys at port yamaha a pm. They have a section at bottom of the forums and I'm sure they'll be able to find you what you need.
I have had to replace mine a couple of times also. I just went to my dealer and told him I needed a new high beam switch. A week and about 4 bucks later I had a new switch. It just snaps in. Piece of cake.
homer2210 - the part number you need for just the button is 8GL-82526-09-00 and we sell them for $5.51 - we have them in stock and if you would like to get one from us just enter that part number in the following link and send the order through online or give us a call. Thanks
http://www.portyamaha.com/fiche_select.asp
