Jack_Shaft
towing said:hi
I have been for little more than 12 years with Polaris, my last two sleds were touring and i put 15 000 miles on each (4-6000miles/year)
I have switch to the yamaha with high expectation and i have been deceived
On the good side, the motor as you know is handsome. The power band is great and the fuel usage is very good. The look of the sled is really the best in his class. The seat is really confortable.
On the bad side. no storage area, passenger hand warmer very weak, slide wear unacceptable, track noise very loud between 50-60mph.I ride 100% of time with a passenger, the rear just not accept the load of a passenger without bottoming. I only weigth 150lbs and my wife 115. It was a major issue here in quebec. Yamaha pass the heavy duty spring on warranty. With all crank at the top it is not too bad but far from my old polaris. The steering become heavy too when you crank up the rear to get your suspention travel... ski lift increase as well...
On the mecanical side, the rear cam braket break (Springs bite in the track and scrap it), jackshaft break. bearing scrap, suspention bushing wear too fast... My last Polaris were less wear for 2-3 times this milage...
I think yamaha will work on many of those issues for 2006.... but my 2005 experience is disapointing. I expected more quality for the money...
i have 4300 miles done
Alain
Alain, I have read and fully understand your post, but I believe that you are in the minority with your abundance of problems to report with the Venture.
If you managed to get 3 times the mileage from a recent Polaris Touring sled before you ran into the amount of trouble you encountered with your new RS Venture, you are a unique case. In our service department, we have over 40,000 km's logged on RS Venture's this year in some of Canada's harshest winter conditions (wayyy North of where you are, son) and the Polaris maintenance that we see here on a regular basis far exceeds what we have seen from the RS Ventures. Personally, I have about 3000 km's on a demo RS Venture that many, many people have driven in just about every condition imaginable and it has not as much as squeaked this entire season.
At 3500 km's, you saw some water in your ccase... did you run on some sloppy trails? Did you encounter any water holes during the early season or Spring melt? Did your dealer give your sled a good checkover at 1500km's or so? He should be able to catch these things quickly and service your sled in order to avoid any long-term damage.
Once again, I am boggled at how your Polarises have shown so much better quality over your RS Venture. It has been our traditional experience that the Yamaha 4-stroke product (RX & RS) has been superior to any other sled on the market with regards to durability and longevity.
With everything that you have said, are you really disappointed with your RS Venture?
-JS
