Bpatch50
Does anyone know if the track clearance on the new RTX SE will be any bigger than on the RTX's? I'm looking to snocheck one and am wondering what's the largest lug track I'll be able to install on it. I won't run without studs so removing the tunnel protectors is not an options. Thanks for any help.
-Tim
-Tim
Kråkan
If the SE is like the RTX you could put a 1,75" track in it like it is. just cut the track down where the protectors are so it will clear them... Or put on 8tooth drivers and it will clear the protectors eaven if not cut down...
Bpatch50
tracks
Thanks for the reply. If that's the case, I should able to do a 1.5 inch track with studs up the middle? Anyone have suggestions on which track to use? I don't ride deep powder - almost all trails and some occasional drag racing / hill climbing.
Thanks again.
Thanks again.
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
Re: tracks
I don't think thats a good idea.
1.50 studs are the longest studs you can use, you should add 1/8"to 1/4"to you your tunnel protectors just my .02
Bpatch50 said:Thanks for the reply. If that's the case, I should able to do a 1.5 inch track with studs up the middle? Anyone have suggestions on which track to use? I don't ride deep powder - almost all trails and some occasional drag racing / hill climbing.
Thanks again.
Bpatch50
track option
So what would be my best option considering I'm going to stud? A Camoplast Cobra track?
Re: tracks
I originally had a 1.5" with NO studs on mine and it would even rub on landings...U need to change the drivers to run any sort of aggressive track with studs.
Thanks again.
Kråkan
1,5" ripsaw has never rubbed at anything. alot of bottoming and alittle jumping etc on the track. Anthough the ripsaw might not be the best racing track imo it is a great trailtrack.. Very durable..
AIRWOLF
Guest
- Oct 1, 2004
- New York
Kråkan said:1,5" ripsaw has never rubbed at anything. alot of bottoming and alittle jumping etc on the track. Anthough the ripsaw might not be the best racing track imo it is a great trailtrack.. Very durable..
Durable,,,I don't think so
