rx-1 mtn with apex rear rack
krauss2005
northwest ohio
i see that the new apexs have a plastic rack on the back track extension with a tail light built into it. would one of those fit o an rx-1 and would it wire up easy. i think it would be cool if i could use that space for storage instaead of wasting it bc we all know theres not much storage on the rx-1
I have read a post in here with a guy that installed a Arctic Cat M series rear rack. The part number is 1706-195 and this does not include tail light. Its from the 2005 900 King cat. If you make a search here: http://www.brownsleisureworld.com/ and go in the part finder for the model above in the seat/rack... section you will see it.
Martin
I have both. The King Cat rack works and looks good. I had it on my stock tunnel extension but never put it on my Hartman rear extension.
I bought an Apex Mountain rear rack but haven't installed it. I have put it in place a few times but it will take some modification to make it fit properly. I'm not so sure I will use it.
Frosty
Get the Fabcraft rack kit, small, out of the way and will work for many different items.
The so called rack on the mountain sleds is junk on the vector mtn and the Apex mtn. I own the vector and my dad has an Apex and you can't even use them. No place to tie #*$&@ down and right behind the exhaust. So stock version is not a very convenience carrying place. But the aftermarket rack for the tunnel extension is something I am looking into. Sort of like the pic above but with a seatback.
