Rx Warrior or RS Venture
lkylyndy
none
After much research I am still confused. As I look at a 2005 Warrior I can't help but think it's very similar to a newer venture. Could someone please clarify the differences? Thanx
The Warrior has a 4 cylinder engine and the Venture has a 3 cylinder engine. The Venture is a 2 up sled, but maybe you meant a Vector. The Warrior is a one up sled with a 136" track. The RS Rage is pretty much the same machine as the Warrior except it has the 3 cylinder engine and a 136" track. Hope this helps a little.
