RX1 2003 reverse handle replacement
Ployus
Canada
Yamaha RX1 2003
Hello !
Just received my new reverse handle (other one snapped yes)
I'm trying to find some instructions on how to replace that ... Anyone did that already and can provide some tips and tricks ? Thanks
Yeah i removed the bottom clip and trying to push the pin up ... It moved a bit but the area is restricted i cant figure out to pull it out... Was wondering if i have to remove the assembly to do the job ?
I replaced mine after the JB Weld finally gave out. I used a window sash handle, .98 cents. Drilled thru shaft and bolted it on.
