Rx1 belt squeal
Massachusetts
2003 rx1
Hi all, got a question, belt squeal with a new belt, squeal coming from the primary, no performance issue , just a squeal, belt sit up a slight bit above the secondary, could be tight, idk, anyone see this,,,,,
You either need three new bolts for the backside of the secondary or you can remove the washers on those bolts and put them back in.
By becoming a VIP member that helps support this site, you are able to get access to the full service manual as a picture is a worth a thousands words:
