rxboost05
Guys
Got to do some testing. Iam seeing 15.5 at idle with 127.5 mains, clips dropped 1 notch, and pilots turned in 1/4 from stock. I am seeing 13.5 on a/f on about a 1000 ft run across field, rpm about 9000 to 9500. no air leaks and very good fuel. Stopped testing as to do no dammage.Any ideas were i can go from here????
Rx1M5
I'm just going thru a similar thing with my turbo. From what you have said 130's will likely put you in the 12's at WOT and 132.5 will get you into the 11's. I was at high 13's low 14's with 127.5 and went to 135's. My new WOT a/f is 11.33 pinned at 8 lbs. As for the idle mine is usally in the 10's. Are you still at 17.5 pilots?
Rx1M5
Rx1M5
rxboost05
Rx1M5
Yes pilots are still stock 17.5s. I will try 130s and the next size larger pilots. As soon as we get snow again i will try and let you know. Thanks for the info, i think this thing is going to be an interesting ride
rxboost05
rxboost05
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
This is where I wound up- 130 mains 17.5 pilots 15m floats @ 10-12 boost
I showed 10.5-10.7 WOT 11-12 cruising 13-14 at idle this was with 110
VP leaded straight-this year 104 sunoco unleaded-will keep you posted!
rxboost05
millstreet
Just got jets today, will ck float levels and test, if it ever snows. will let you know results.
SPEED
!8 inches in Big Moose and 14 inches in Old Forge,Let the rodeo begin!!!!!!!
rxboost05
Any ice on the lake at Big Moose ????
Fergie
- New Jersey-Ride Old Forge N.Y.
No ice anywhere, just 14" of fresh snow with no base.
