RX1 with ripsaw 1.5 inch track. help question
polarisnow1
Grand Blanc Michigan
A question for everyone. I have a 2003 rx1, I have rail extensions and a 1inch x 136 track. I am looking to put a 1.5 ripsaw track on with woody's 1575 studs. I have stock 9 tooth drivers. It looks like I have enough clearance but I am wondering if anyone has done this set up and if the track and suds will clear the front heat exchanger. I do have front tunnel guards an looks like I have almost an inch between current 1inch track and the guards. Ideas suggestions or thoughts welcome. Thanks in advance. :yam:
I would strongly suggest that you avoid spikes with that tall of a track. You would be better off obtaining a PREDATOR 1.25" track and using shorter steel. The PREDATOR 1.25" track will give you MORE traction than a ripoff 1.5" track -- its a winner all the way around.
Hey, LazyBastard is Back! I thought you said you would never come to this site again? You are welcome to be here just make sure that you show respect to all members and do not mistreat or talk bad to or about anyone! :Rules:
why did you change your site name?
