Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Does anyone know of a good safety tether switch I can add to my Warrior and what is the best way to wire it.
I located the brown wires on the kill switch, the problem I ran into last night is the tether (I was told would work if off an arcticat) when I tested it, I found out it is normally open
So I would like to know if anyone knew what tether would work on Yamaha and what wires your hooking in to.
Pictures would be nice
monker
I used a wire going to the kill switch as you mentioned. I spliced into that wire and used a male and female wire connector. This way if there ever is a problem with the teather, you connect the kill switch back up. You do need a normally closed switch though. At the time I remember having a hard time finding one. I think I got mine from Dennis Kirk. It is mounted on the plastic that is over the gas tank, opposite the key switch. The wireing runs up the steering post and is connected under the handlebar pad.
http://www.denniskirk.com/jsp/product_c ... Id=&mmyId=
monker
I can get pics this weekend if you want.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
I was just running a search and came up with an answer, I should have done this first.
I didn't know there was an Old style ( normally Closed) and new style
(normally open) teathers.
I just went to the Articat dealer and pick one up not knowing.
