Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
What is everyone using to clean your seat? I want to clean the red strip on my Apex seat.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
cleaning
Use varsol first then spraynine.Varsol is a all purpose cleanner,I used it every were it works very well.Just make sure it is varsol all purpose cleanner not paint tinner.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Cool. Thanks. Never thought of Varsol. Spray Nine was on my mind.
snerkman
LA Totally Awesome cleaner. Get at the dollar store for a buck. It's what many boaters use to clean their vinyl (that's how I found out about it.) Kicks #*$&@!
WD-40, clean rag and elbow grease
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
Whitewall tire cleaner- may dilute depending on which one you use.
sherlock29
If you use spary nine, wipe it off after with a wet cloth... over time it will make the colors fade faster in the sun... if you rub hard enough with it too it can take the dye off the seat cover.... its happened to me on other sleds. IMO.
Varsol??? do you need something that strong to clean your seat??? great degreaser but kinda nervous using on a nice soft seat cover...
Westley tire bleach.
happy1426
i use spray nine on all my sleds never a problem as i do it in my garage with the heat on no sun and when it goes back out side its dry and im moving so fast the sun dont get a chance to fade it!!!!!!!!!!!!!!! ![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
yamahahaha
spray 9 then water so the seat wont be greasy/sticky after
sherlock29
Cheers happy1426...... yes notice how i said in the past... hehehe... yep these yammis move.. ;-)
but yes... spray nine works great!!!
cheers
cheers
mdkuni
Amazing Vinyl Cleaner by BioKleen.
Use an old toothbrush on the seat with the cleaner and it will look like new. You need something to scrub the seat to get the grime that is deep in the material. A old toothbrush works perfect with very little effort.
AC Delco Spray Cleaner. Get it at GM dealership parts counter. It works excellent. I use it on everything.
