Wanting to remove the secondary clutch from my 2003 Rx1. Any tricks to this? I havn't had the chance to go check it out yet, it doesnt seem like it will be a hard task. Any help or info is appreciated. Thanks!
when your 12 mm wrench dont work try a 14mm, and as said watch the spacers including the one that can stick to the back of the secondary and fall off later.
My parking brake wouldn't hold it. It's studded and I just put the track on the ground and it worked fine. Just another idea for anyone doing it. How long does the bearing behind it "usually" last?
My speedo bearing needed replacing at 3000 miles so I ended up doing all of them. The Jackshaft bearing was still good and probably would have lasted a lot longer with regular greasing. There are a few threads on here about how to grease it either by removing the seal or injecting through a small hole with a needle tip.
