19SRX
- Oct 10, 2018
- Ottawa
- 2019 srx le
Anyone ever experienced this..just below full tank of gas, had the back of my sled about 2 ft off the ground to install my studs and noticed gas dripping at the front? Could that be normal? Coming out of the tank vent?
Fleecer
- Jun 13, 2014
- 2019 SRX
Yup, youre right, normal and coming from vent!!
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Check the rubber grommet at the vent. I needed to replace it when I changed the elbow cause the rubber stretched when I removed it and it leaked a little.
- Sauk Prairie, WI
- www.ty4stroke.com
It will leak like that when the rear end is jacked up. Especially with a full tank of gas
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Tipped my car over and it didn’t leak, sled really shouldn’t, guys in the mountains tip over all the time and don’t leak gas, I would check to see were it’s coming from. Gas causes fire you now,!
