muskrat
I keep cooking my K&N because it is mounted on the turbo. Anyone modified theirs? How big of an air filter do I need for 03 RX1 running 8-12 lbs? Thanks for help.
snowy1
you need to get the filter away from the compressor housing, using silicone hose and aluminum tube, 3-4 inchs will work or more if you want to put it where it can get cooler air, just need to keep it from being connected directly to the housing. the compressor housing gets to hot for the filter flange material.
tonykof
Picture of change?
Anyone have any pictures of how you changed it?
tk
tk
yamamax
Anyone have the K&N air filter number for the CPR system?
looking4speed
RU-1710 is the part #.
muskrat
filter
Thanks, however there is not three inches to spare. Where did you locate the filter? I have no room. I could maybe slide my filter 1 inch forward , that's all though. I could use a 1700 filter, that is 4 inches instead of 5 inches long. How much silicone tubing can I run without it affecting performance. Will a 4 inch filter work or will it starve for air?
MM
MM
yamamax
Thanks for the number
I also did the same as snowy, my air filter sits behind the windshield. Got a muffler shop to bend a piece of exhaust pipe, used silcone hose at the turbo and put the air filter above the valve cover, then put an alu heat shield on the motor. I didn't fit the best, the the air filter lived.
tonykof
I know it's kind of a pain in the butt but if the guys that have come up with a better way of to mount the filter could post some pictures it would be great.
thanks tk
thanks tk
snowy1
if you look at the post titled a few pictures of my changes you will get an idea, its 8 post down fom this one. if you use a 90 degree elbow and direct it towards the chain case side it should work.
tonykof
Anyone know the part # of the Tapered k&N filter that some guys are using?
tonykof
This is originally an old post but I'd still like to know the part # of the tapered filter???
Thanks tk
Thanks tk
powderlites
melting filter
Put proper cooling hoses into center section of turbo. Don't use small hoses off head but the ones off oil cooler 7/16"
Hose from cooler to turbo then back to thermostat housing.
http://www.powderlites.com
Rx1M5
