Skid Istallation 04 Warrior
kodiak
I am in the process of installing a new track on my 2004 RX Warrior. I have the new track on but I am having trouble bolting the skid back into place.
I started by installing the bolts at the front of the skid and then the back bolts but I couldn't get the shock mount holes in the middle to line up inside the tunnel. I tried taking out the rear bolts and install the centre bolts first but I still can't get it into place.
Can someone let me know what I'm doing wrong and tell me the proper way to install the skid.
Thanks for your time.
Loosen the lower bolts in the Control Rods to the point they are only screwed in about 5 turns, on both sides. Install the Suspension bolts and then tighten the lower control rod bolts. As you loosen these control rod bolts, the control rods are allowed to be longer, which will allow you to position all six suspension bolts w/o any problems.
