iasledder
Is there a problem with laying the sled on it's left or right side to do work? Concern is for oil going where it shouldn't.
RDPOWER
- Apr 2, 2006
- 2012 YAMAHA APEX XTX
the owners manual states not to lay the sled on the clutch side (because fuel may leak from the vent) - so i put my sled on the oil tank side - i didin't have a problem but it's still a good idea to check all of your fluids when you are done - (yamaha sells a stand to rest your handlebar on so they must feel it is ok)
DYNAREX
also if its on the clutch side the little bit of engine oil bleeds out of the breather box and into the airbox but not too big a deal
Bigger Hammer
Might want to put a block of wood or somthing under the handlebar, I have heard of people cracking some of the plastic parts (i.e. headlight pod)
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The demo guys in Muni last year were doing alot of maintenance with the sleds on the side, just can't recall which side.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Tip it on the right side or oil will get into the airbox
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Are you saying the Right Side when you are sitting on the sled (Chaincase Side) /Convert said:Tip it on the right side or oil will get into the airbox![]()
jimmie d
Side is always based on you sitting on sled.
Jim
Jim
Convert
- Apr 14, 2003
Tork
The body work is lighter on Delta II so thus it is more flimsy.
I'd put a block of wood under the tip of the handlebar (Pat's Yamaha in Greenland MI does this).
Interestingly Yamaha sells a stand that does the same thing (but better) so they must endorse this as a preferred method
Handlebar Stand
Used to help prevent machine damage when machine is tipped on its side for maintenance. Simply put handlebar end of machine in handlebar stand. Stand is adjustable to accept all handlebar heights.
Blue
SMA-STAND-HB-AR
Handlebar Stand
Blue
SMA-STAND-HB-AR
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
OOPS
I put it on the Lt or clutch side with 2x4 on steering post when taking the mono in and out seemed to start and run fine after, well now I know.
thanks for the info guys,
Happy thanksgiving,
We are Blessed for sure in this country and to have the resouces and health to have this hobby.
Yamadoo
Happy thanksgiving,
Yamadoo
iasledder
Laying on right side makes it a little difficult to work on the chaincase. Of coarse this can be done with sled sitting upright. Thanks for all of the replies, good infos.---Jim
