kuvasz
I've worked on my sled over the last yr after installing the stage 6 by TD. I had a hard time trying to dial the sled in because of the boost changed on my max 20 tune from 20lbs to 17.8lbs. I've had a "lot" of help from jason from turbo dynamics and now I can run 21-22lbs safely on pump gas all day long.
Last yr I won at the nbssr open power adder class at 133.2mph with good ice and below 0c temps. This yr we ran the new spec2 pump gas only class with 132.8 and 131.9 on different weekends. This yr the ice was soft and by the afternoons as our temps ran from 8-10c on both weekends.
I would like to congratulate the guys who ran the spec 1 class which is the same rules as mine except they can run race fuel. I would like congratulate travis for running 134.7 in this class. I would also like to congratulate bill, jeff and others for running 133-136 in this class.
What I've found is the sleds speeds are getting very consistent in the low 130's in 1320 which is getting better on pump gas only. I was hoping for better speeds, but for the temp and conditions it is was what it was. There's always next yr.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
How did u get the boost from 17 to 21 ?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
good question!How did u get the boost from 17 to 21 ?
T-rav 27
- Apr 16, 2017
- Sudbury
- Srx 700 imp,1100 turbo, mcx apex
Congrats Andy a little time and alot of testing goes a long way it's been a battle for me aswell and I'm slowly getting a figure on things but now I need gear and I'm sure this sled will be consistent 135 and over I am not as fearless as u to go to 22.5 lbs on pump lol I'm just to scared but ur sled ia a rocket and I'm very happy for u keep up the hard work
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
He would be partially locking waist gate or stiffer actuatorHow did u get the boost from 17 to 21 ?
