np342403
Does anyone have the Sno-Stuff Rumble Pack on their Phazer? Any thoughts on them as far as performance, sound, etc?
MikeWalters
Save your money, it is a cherry bomb muffler. Seriously I am not joking...
If you are looking for a "slip-on" there are better options (although you will have to cut no matter what).
-MBRP is loud and drony (apparently)
-Aaen is loud but not drony, definitely felt an improvemnt in power personally (Aaen pipe does not exit under the seat straight out, it angles to the side a bit)
-Schmidt single not nearly as loud and still offers weight savings and a little bit of horsepower (probably the nicest looking muffler also)
-Might be some other ones out there but I haven't looked
Or if you got some skills you could find a Yoshi RS5 or something like that and do it your self.
Good luck
Good luck
np342403
MikeWalters said:Save your money, it is a cherry bomb muffler. Seriously I am not joking...
Good luck
That is the info I was looking for. Thanks! I will stay away from the Sno-Stuff!
MikeWalters
PS - where you from?
np342403
MikeWalters said:PS - where you from?
Northeast Ohio
MikeWalters
Site rules we are supposed to put location in.
Welcome to club Phazer.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
There is also excell.
MikeWalters
Yes I knew there was another.... thanks.
RayKnobs
MikeWalters said:Site rules we are supposed to put location in.
You should double check that
No more Excell exhausts. I called to order one and they said the dont have any more and they arent sure if they are going to produce more. Bummer!
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Skinz makes two different ones.
The quieter one (Ultra Q) is actually sold by Yamaha as an accessory under their name.
I have one, it's lighter and sounds good. It also uses the stock black exhaust cap thing on the back of the sled.
Zakre
RayKnobs said:MikeWalters said:Site rules we are supposed to put location in.
So should you, its in there .
MikeWalters
Hey i wasnt trying to start an argument, lets stay on topic. Not sure what the big deal is about hiding your location anyway... perhaps enlighten us Ray K...just for curiosity sake.
Anyway, np342403,
u get the info you needed? there are a lot of vids on youtube if you just search for "phazer exhaust" if you want to listen. They are ALL louder in person I might add....good luck.
make sure it is legal in your area also...
Anyway, np342403,
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Site only requires you to list your location if you're using the classifieds section.
MikeWalters
Jeffz said:Site only requires you to list your location if you're using the classifieds section.
Okee, now I understand. Thanks for clarification.
