kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
So in the front mount applications there is the space underneath the header itself. To prevent movement of the header could your you put some kind of high temp rubber/ silicone/ plastic under it preventing the header from moving downwards. Ill be wrapping the header anyway so the temps should be down enough for the material not to melt. What do you guys think.
Some_Boost
- Aug 8, 2012
- Corrunna Ontario
- 2015 Outlaw Viper
You could ceramic coat the header to help lower the radiant heat coming off the header .
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
About how hot would a wrapped ceramic coated stainless steel manifold get. Im still trying to hunt down a person that will make the header and then I have to hunt down the silicone or rubber
