Spark Plugs
curryd
Kingston, MI
How often are you guys changing them and are you going with the same plug or switching to the plug Ulmer sells? Also, can they be changed with the tank still on?
Lot of people using ulmers plugs. Yea you can change them with tank on. Just pull clutch side, side panel off. Pull the coils off the plugs and then take the socket with an extension and put it on the plug then you can put rachet onto the extension while its on the plug in the sled. Was easiest way i found. Only took a few minutes
snowgoer has a great article on it this month. It shows step by step (FEB2010)
Yeah its a great article but it is way easier and faster the way 08fxnytro explained and I also went to the cr10ek's.
