spoke accesory wheel question
dexter
Maine
do the newer spoked accesory wheels from Yami fit all skids? I had some on my apex and wanted to put them on my warrior, but the inner diameter of the bearing is too big... I thought they fit all models?
There's two versions...the big bearing wheels fit the 2010+ mono skid....I made the same mistake. You want the wheels off of a 2010+ Nytro they have the small bearing.
thanks guys... that is the wheel I want and have, but I guess the bearing is for the newer mono... I wonder if I can swap out the bearing? thanks!
Was checking in to this for myself. Rear wheels up to 2009 for apex have a 6004 bearing. The 2010 and up wheel has a 6005 bearing. The od and id are diferent so You just can't change the bearing.
Any sled with the Mono 2 skid has a larger rear axle (2010, 2011, and subsequent year Apexes and Vectors) so needed a larger bearing for the rear wheels.
