Spring rate for 08 FX?
TRUTH
Wisconsin
Hey all,
Does anyone know what the spring rate is for the stock 08 FX front shock springs? Thanks! Frank R.
from www.pioneerperformance.net
The Nytro FX is on the firm side as far as the front end ride. Reducing the dampening adjustment still doesn't take care of the problem. By replacing the stock 2.5 kg/mm springs with a set of our 2.3 springs, ride is improved, making the front end more compliant in the smaller bumps.
The Nytro MTX uses a very soft 1.7 kg/mm rate front spring. These springs work fine for certain conditions, but on the trail it creates excess body roll. By installing a set of our 2.3 springs the MTX will be much more stable and predictable when turning.
P-S113.....PP 2.3 Handling Front Suspension Springs (pair).....$99.95
ski
