JERSEYJOE
WHAT IS THE STOCK SETTING ON AN APEX GT SECONDARY CLUTCH ( 2006)
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Found an old thread that Turk, the clutching guru was in and he said it works best on 6 on helix & 1 on secondary, even thou the manual says it sould be 6 & 2.
I would go with Turks recommendation, He knew his stuff.
JERSEYJOE
TURK
HEARD OF HIM. WHERE DID HE GO?
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
Unfortunately he passed away, I believe a couple of years ago.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
6 on cover and 1 spring hole is stock. Go 6 and 2 for 80 degrees. Sheave hole # + spring seat hole # =degrees. Stock is 70 degrees. Any combination can be used. I believe 80 works best if all else is stock...
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
I always though stock was 3-3 60 pink spring?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Manual says 3-3 or 6-1. mine was 6-1 so i tightened 1...
