storing apex for summer
rossbowe
Perrysburg Ohio
What do I need to do to my 2012 apex xtx for summer storage? Do I fog it like my FXHO watercraft? Do I drain the fuel tank? any help appreciated
Change oil, grease it. Pick and grease left side bearings behind clutches. I put in sea foam and run it last tank. Then I siphon out most of the fuel and burn it in my garden tractor.
You can fog it I suppose but I store my sled in the garage and not outside so it stays dry all summer and protected from temp changes that cause humidity to build up inside all the things you don't want humidity to build up in.
Sea-Foam, run it through the sysytem (10 mins) Fog until it stalls, syphon fuel.
Then, of course the rest of the normal summerization steps one thinks/finds necessary to do.
Ie: chain case oil change
Re-grease/replace bearings in skid, jackshaft, drive shaft
remove battery, clean/wash sled etc etc etc.
