suspension wheels on pro action rx1
rx1 fern
thompson mb
hello ,my 04 turbo rx1 is in need of some idler wheels.the back wheels are the worse ones and they are rattling,this is what happens on high horse power sleds.i am looking at upgrading to better ones ,can you guys give me some advice and part numbers for them also.i hear lots about the skidoo wheels.this would be for all the wheels on my o4 rx1 with the proaction that i extended to a 144 .my sled still has the original wheels on her.thanks for any help,fern.
If you're looking for a good INEXPENSIVE, but durable wheel, you should take a look at the older aluminum hub wheels from any yamaha about 1990. They are cast aluminum wheels with a rubber tire, and take 6205 bearings, which will fit on your shaft.
thanks for the reply.i ended up ordering some yamaha ones from royal distributing .they have replacable bearings on them so that is a good idea since the bearings are what gets wrecked.
