the throttle body boots blew off my supercharged phazer.i think it was due to improper installation.at any rate;it now is coding a 14.i looked it up &it says intake air pressurehose clogged or detached.i re-attached the boots as it said.after idling it is supposed to re-set the code correct?thats what it says in the manual anyway-but it wont.i unplugged the battery too-no luck.does this mean the sensor is shot?it is now impossible to start unless you hold the throttle partly open.any suggestions?
