Hi just got a new to me 2010 nytro xtx a week ago and been reading ever since on how to make it the best it can be. First thing I did was replace the stock skis with tuners. the manual says difference for toe out from centre of front to centre of back of ski should be 15 mil. Like a dummy I didn't measure the stock ones and installed the new tuner skis. Is the toe out supposed to be the same as original? When I measure the new ones I have close to 40 mll difference from centre of front to centre of back. What is the easiest way to adjust this if I need to?
Old man winter, I have an apex LTX and set my toe out about the same as stock. I am between 1/8 in to 1/4. Close to 1/8" as possible. I am running 4 in carbide in middle with 2 in outside and she handles the best it has since I owned the sled. For me the tunner skis work well. I also bought extra 4 in to try on outside but sled was so improved last year I never tried them. Good luck and hope this helps.
Blue
Thanks bluebullet. I cant get it down to that little without adjusting the control arms and i wss hoping to avoid that. When i put a bungee across to hold the front of the skis tight it brought the difference in width down to 3/4 of an inch wider in the front centre to centre of the skis to the back centre to centre of skis. Not enough snow here for a test ride yet
